Activity Forums DSLR Video H264 compression shifts gamma only in original DSLR footage
  • H264 compression shifts gamma only in original DSLR footage
    Posted by Lindsey Grayzel on October 4, 2011 at 8:16 pm
    Hello,
    I have been reading all the various posts about H264 gamma shifts all morning. Here’s my workflow:
    Shoot on 7D DSLR and Sony Ex-3
    Convert the DSLR footage to Apple Pro Res
    Edit in Final Cut 6.06 in an Apple Pro Res timeline. (Ex-3 footage gets rendered in timeline.)
    Everything looks beautiful.
    Export full res. quicktime file with current settings.
    Everything still looks beautiful.
    Compress to H264
    Now the shots that were originally from the EX-3 still look beautiful, but the shots from the DSLR are washed out, low saturated color.
    I can get the DSLR shots to look beautiful again by adding a gamma correction filter of 1.2, but that makes the shots from the EX-3 way too dark.
    Incidentally, I’m using a Matrox box for the H264 compression, but I have tested without it and get the same results, so I don’t think that’s figuring into the mix.
    I’d appreciate any and all suggestions!
    Thank you,
    Lindsey
    Owen Wexler replied 14 years, 10 months ago 2 Members · 1 Reply
  • Owen Wexler
    October 17, 2011 at 6:35 pm
    Quicktime H.264 is notorious for its gamma issues. If you have Adobe Media Encoder, try using that to convert to an H.264 MP4… that might help.
    Cinematographer – Editor – Motion Graphics Artist – Colorist
    https://www.owenbwexler.com
