Activity Forums VEGAS Pro H.264 (Canon .mov) crashing Vegas 9.e Part 2
  • H.264 (Canon .mov) crashing Vegas 9.e Part 2
    Posted by Al Bergstein on August 5, 2010 at 1:01 am
    Ok. So I read the earlier threads about how Canon .mov H.264 files crash Vegas 8.x. I purposely bought Neoscene to convert my Canon .MOV files and now I find that I crash Vegas (not Windows) with large size .MOV files, regardless of conversion to .AVI or not. (both AVI and MOV versions of the same clip crash Vegas). It seems that I get about 4 or 5 clips into Vegas and the crash happens (repeatable).
    AVCHD files render fine. Some smaller .mov have no problems.
    Has anyone heard of a reasonable fix for this? I’m going to migrate them onto my Mac and try them on that “other editing tool”. Obviously I’ll be converting them there as well,but maybe Pro-res will handle them better. Oddly enough, my friend’s JVC drags and drops MOV files to FCP with no problem. Wonder if it’s something inherent in the files created on these new 7d and T2i? But they have been out there a while…Could be the new huge sensor size requires vastly more compression than the tiny (but expensive) sensors on the higher end JVC gear?
    Alf
    Al Bergstein replied 16 years, 1 month ago 2 Members · 2 Replies
  • Frederic Baumann
    August 5, 2010 at 9:45 am
    I had the same problem, and bought Cineform which fixed it.
    However my .MOV are 30-second long maximum.
    Did you try to convert them to AVI with ZoomBrowserEX, which is shipped with the 7D? I heard it was also doing a good job (and btw if it is true, then I am a bit sad because then I waste 100 euros in Cineform).
    Frederic
  • Al Bergstein
    August 5, 2010 at 1:34 pm
    I’ve not tried Zoombrowser, because my clips haven’t crashed my machine up to now. But, these latest clips are the longest I’ve shot. So I will try using that. Cineform did not change the problem at all. Once converted the clips, when I reached a certain length, still crashed Vegas.
    Alf
