Activity Forums Apple Final Cut Pro Legacy H264 audio need render?
  • H264 audio need render?
    Posted by D Hudson on June 16, 2010 at 1:32 pm
    H264 issue:
    used compressor to transcode all my H264 to proress. In FCP the files work fine cept the audio is always red lined. have tried several settings including pass thru. always red lined.
    Working on a 2010 macbook pro with FCP7.
    D Hudson replied 16 years, 3 months ago 3 Members · 16 Replies
  • 16 Replies
  • Jeremy Garchow
    June 16, 2010 at 2:17 pm
    Audio needs to be set to PCM 48k 16 or 24 bit.
    Are you using Canon footage? Why not download the log and transfer plugin?
  • Mark Petereit
    June 16, 2010 at 2:29 pm
    Convert your audio to AIFF.
  • Jeremy Garchow
    June 16, 2010 at 2:31 pm
    which within the compressor dialogue translates to ‘Linear PCM’.
  • D Hudson
    June 16, 2010 at 2:54 pm
    Not cannon: but Flip and JVC
    dhudson
    sr.editor PVC
  • Jeremy Garchow
    June 16, 2010 at 3:01 pm
    Got it. Then change the audio settings in compressor to what was mentioned before.
    Linear PCM, 48k 16 or 24 bit stereo.
  • D Hudson
    June 16, 2010 at 3:16 pm
    issue seems to be related to the sequence I am tring to put shot into:
    seq 1 is DVCPro 720p 60 audio: 48 16b
    seq 2 is Prores audio: 48 16b
    audio setting are the same yet in seq 1 I get red line for audio and seq 2 all is good is this correct?
    dhudson
    sr.editor PVC
  • Jeremy Garchow
    June 16, 2010 at 3:51 pm
    [d hudson] “audio setting are the same yet in seq 1 I get red line for audio and seq 2 all is good is this correct? “
    Are you sure the audio is the red render line? Are you making your own timelines or letting FCP conform to your footage?
    Look in the browser and scroll to the right to double check your audio format of your footage that you made out of COmpressor.
    Jeremy
  • D Hudson
    June 16, 2010 at 3:59 pm
    If I use the H264 converted footage first and let FCP seq match footage no red line. If I use the P2 footage first and let FCP seq match that the H264 converted footage gets a red line. Now, When I look in browser both clips have the same audio settings ( that I can tell) Aud Rate: 48 K bit rate: 16-bit integer.
    dhudson
    sr.editor PVC
  • Jeremy Garchow
    June 16, 2010 at 4:03 pm
    ALright DHudson, I think you aren’t quite setting things up properly, but we can help you.
    Tell me all the formats that you have in your project, and what timeline you are planning to edit in (frame size, codec, frame rate, etc).
    Jeremy
  • D Hudson
    June 16, 2010 at 4:10 pm
    Main cam and majority of footage is P2 960×720 23.98 used log and tran to import this
    FCP matched footage to be DVCPro HD 720p 60 (960 x 720) edit Time base 23.98 audio is 48k 16b
    Flip cam is orig 1280 x 720 H264 AAC converted with Compressor to ProRess 422 (lt) various audio have been tried currently set at Linear PCM 16b
    dhudson
    sr.editor PVC
