Activity › Forums › Apple Final Cut Pro Legacy › H.264 1080P60 encoding
  • H.264 1080P60 encoding
    Posted by James Wright on August 14, 2009 at 12:41 pm
    I’ve got some H.264 1920×1080 60 fps progressive scan footage and I was wondering what is the best way to import it into Final Cut Pro with minimal loss of quality/frames in the encoding process? Will MPEG Streamclip suffice? What are the ideal export settings? Exporting to quicktime with a DV Codec doesn’t seem to work anymore.
    Arnie Schlissel replied 17 years, 1 month ago 4 Members · 4 Replies
  • Nick Meyers
    August 14, 2009 at 12:52 pm
    Q:
    where to you want to go with this footage?
    what is your final delivery format?
    A:
    compressor will get you there just as easily as Mpeg StreamClip, i think,
    most likely by converting it to a ProRes format,
    but then again…. see questions above.
    nick
  • James Wright
    August 14, 2009 at 1:00 pm
    “where to you want to go with this footage?”
    I don’t understand? Are you asking what I want to do in the editing process?
    “what is your final delivery format?”
    Any format, I’d probably export to quicktime H.264
    What settings should I use in MPEG Streamclip/Compressor?
  • Rafael Amador
    August 14, 2009 at 1:40 pm
    Hi james,
    Although H264 supports even 10b and 4.4.4 structures, the standard H264 we get when compressing with QT, Compressor, etc is 8b and (I guess) 4.2.0
    8b Uncompress would be the codec that would keep the full quality when converted.
    An 10b codec would be unnecessary. Any other 8b codec would re-compress the picture.
    PhotoJPEG 75% would be another good option.
    Cheers,
    Rafa
    http://www.nagavideo.com
  • Arnie Schlissel
    August 14, 2009 at 2:28 pm
    Drop it into Compressor and convert it to ProRes.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
