Activity Forums Adobe After Effects Guys I need to put a video into a text and….
  • Guys I need to put a video into a text and….
    Posted by Bobby Sifon on December 5, 2021 at 3:12 pm
    Hello Guys
    Below is an image of my project with a shape and a “R O B E R T S D I G I T A L” text below it.
    Behind the shape and text is a video.
    But I’d like the video to appear inside both the text and shape
    And I want both the shape and text to slowly zoom in by just 1cm [inwards]
    then finally i want the video inside the text and shape to gently “fade out” leaving the shape and the “D I G I T A L” in red as displayed in the second image below
    A recorded video explanation would be much easier for me to follow and understand as I’m a newbie to ae. Thanks
    Below is a link to my files
    https://files.fm/u/jdkzvhky2
    Levi Borland replied 4 years, 9 months ago 3 Members · 4 Replies
  • Tero Ahlfors
    December 5, 2021 at 5:58 pm
    You could use the logo and the title as track mattes.
    https://www.schoolofmotion.com/blog/how-to-use-track-mattes-after-effects
  • Levi Borland
    December 5, 2021 at 6:38 pm
    Pre-comp your logo and text by selecting them both, right clicking, and selecting pre-compose. Choose move all assets into new comp in the window that pops up and hit enter. This will make a pre-comp in your timeline that holds both on a single layer. Put your footage above that comp and then change the track matte drop down of your pre-comp to alpha or perhaps luma matte. I can never remember which. There are four options. Pick the one that makes the video take the outline of your text and shape. It will also do away with the logo and text’s original colors, replacing them with the video layer.
    Key frame the pre-comp to scale up to your liking over time. Then duplicate the pre-comp and put the copy over the top of your footage layer. Be sure to duplicate the pre-comp after the scale keyframes are in place so it has the same animation as the original pre-comped layer. Turn the opacity to zero on the duplicated copy you moved to the top of your comp…set a keyframe where you want the logo to start fading in over the footage, move forward in the timeline to where you want it fully visible and turn the opacity back up to 100. This will make the logo and text fade in over top of your bottom two layers giving the impression that it just faded away to it’s original colors.
    In reality it is just hiding the footage layer beneath it.
  • Bobby Sifon
    December 6, 2021 at 5:45 am
    Ohh…Pre-compose. I forgot about that..
    I’ll give it a shot and get back to you
    Thanks BTW
  • Levi Borland
    December 6, 2021 at 8:03 am
    hope it helps
