Activity Forums Adobe After Effects GTX 770 : GPU and cuda not active in AE CS6
  • GTX 770 : GPU and cuda not active in AE CS6
    Posted by Thierry Lombry on March 26, 2014 at 9:10 pm
    I use a PC under Windows 7 with a nVidia GTX 770 GC with 4 MB VRAM and an Intel i7 CPU (4 processeurs, 8 threads).
    All is fine except that in AE CS6 I cannot activate the CUDA for ray-tracing.
    This option is in Menu Edit > Preferences > Previews
    then on top right push on “GPU information…” button.
    Usually displayed settings are next:
    Ray-tracing : CPU
    (GPU not available – incompatible device or display driver)
    I found on the web that we can edit the AE file “raytracer_supported_cards.txt” located in AE program directory, and add the line “GeForce GTX 770” but it failed with an error (not blocking) in loaded AE, so I removed it.
    But adding that line, in AE Edit > Preferences > Previews, I can well select the GPU and the Cuda is activated.
    But due to the error at loading I removed the reference to GTX 770 in txt file.
    Question:
    I have the latest drive for GTX 770. How to proceed to activate the Cuda is AE CS6 without error ?
    Thanks.
    NB. I have not store it in the default Adobe folder but in another one (I edited the txt file accordingly)
    Roland R. kahlenberg replied 12 years, 6 months ago 3 Members · 5 Replies
  • Todd Kopriva
    March 26, 2014 at 9:32 pm
    That GPU was added in After Effects CC (12.1):
    https://blogs.adobe.com/aftereffects/2013/09/gpu-changes-for-cuda-and-opengl-in-after-effects-cc-12-1.html
    After Effects team blog
  • Thierry Lombry
    March 26, 2014 at 9:36 pm
    You mean that there is NO solution for CS6 ?
    What do users who do not want upgrade to CC ? They remain stuck with their issue although they paid the high price ? 🙁
    I found something that you should know if you work for Adobe
    https://developer.nvidia.com/cuda-downloads?sid=471928
    I need the confirmation from Adobe that this fix resolves the problem on AE CS6 as at first sight it does not with my configuration.
  • Roland R. kahlenberg
    March 27, 2014 at 12:27 pm
    Hi Thierry, I doubt that editing/hacking the “raytracer_supported_cards.txt” is supported or encouraged by Adobe. I think you should check further, on the Web, to see what other users with your GPU have experienced.
    HTH
    RoRK
    Latest AE Workshop – MoGraph Intensity – Shapes & Text
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Adobe After Effects CC ACE/ACI
    Imagineer Systems (mocha) Certified Instructor
  • Thierry Lombry
    March 27, 2014 at 10:19 pm
    I contacted nVidia Support about my issue with GTX 770.
    nVidia support recommend either upgrade to AE CC or from AE CS6 v11.0 to v11.0.4 as explained here :
    https://blogs.adobe.com/aftereffects/2012/05/after-effects-cs6-11-0-1-update-bug-fixes-and-added-gpu-and-3d-renderer-support.html
    Then I edited the supported_card.txt file as nVidia suggested and added a line GeForce GTX 770.
    I launched AE. In Edit > Preferencec > Previews, the GPU was available and cuda found all the VRAM.
    This upgrade resolved the GPU/Cuda issue (without error, and it run up to 6 times faster in rendering).
    March 28, 2014 at 12:30 am
    I’m glad you’ve sorted out your issue AND reported back.
    I was going to suggest hacking the Prefs.txt which MAY remove the error message but I first wanted to see what you managed to source from the Web.
    Cheers
    RoRK
