Activity Forums DaVinci Resolve GTX 480, 570, 580, 670 and 680 performance
  • GTX 480, 570, 580, 670 and 680 performance
    Posted by Matthew Battershell on July 26, 2012 at 11:48 pm
    I know the 6xx series is not performing with increased performance in Resolve over the 5xx, but I do not know if it is less. As you also know, the 580 GTX is stupid expensive right now, especially the 3GB model. I cannot justify paying into NVIDIA’s price gouging. Seriously, in the last two weeks the price shot up… instead of going down!
    Therefore, on a hackintosh with a 285 GTX already, would you recommend the 670 over the 570 or 480? I’m also banking for performance in Premiere CS 5.5 – soon 6. To tell you the truth, my 285 does pretty good.
    Finally, is there noticeable difference in performance on a Hackintosh with using an EFI flashed mac GPU or just using a regular PC GPU? I understand the 2.5 vs 5 gt bus issue but also heard that it adjusts under load, so system profiler may not being accurate.
    Being on a Hackintosh, I can put any GPU in.
    Thanks.
    Kevin Cannon replied 14 years, 1 month ago 5 Members · 5 Replies
  • Robert Houllahan
    July 27, 2012 at 12:23 am
    The 480 is close to the 580 in performance and is quite cheap right now, I just got two 480’s with water cooling blocks for about $300.
    -Rob-
    Robert Houllahan
    Director / Colorist
    Cinelab Inc.
    http://www.cinelab.com
    MAHC-PRO 6-Core 3X GTX285 20Tb SAS Wave Panel Panny 11UK SDI Plasma. Light-Space CMS + Hubble
  • Juan Salvo
    July 27, 2012 at 3:06 am
    Demand is high and supply is low. Reason for pricing discrepancy with the 580. Get the 570 or as Robert suggested 480 for a better value right now. Heck even the 680 may be a better value, but probably quite difficult to get running on Os X.
    Colorist | Online Editor | Post Super | VFX Artist | BD Author
    https://JuanSalvo.com
  • Margus Voll
    July 27, 2012 at 9:49 am
    I agree with Juan on that.
    Try to keep things reasonable in price sense.
    Margus
    https://iconstudios.eu
    DaVinci 8.2.1 OSX 10.7.3
    MacPro 5.1 2×2,93 24GB
    GTX 470 / Quadro 4000
    Multibridge 2 Pro
  • Matthew Battershell
    July 30, 2012 at 6:13 pm
    ok, so if I have 2 gtx 480’s plus the gtx 285 with a 6 core 3.33ghz running at 3.75ghz, how do you think Resolve 9 with 4k footage will handle?
    I guess the 285 would be my GUI right?
    Would you run the GTX 480 in SLI mode or regular?
    I have a 750 watt PSU, I guess I have to upgrade that?
  • Kevin Cannon
    August 4, 2012 at 8:15 am
    Hi Matthew,
    I just tested some 680s in Mountain Lion and put the results compared against 580s over in this thread.
    I didn’t have too much trouble with getting the 680s to work in OSX, but I haven’t tried to use them for anything but Resolve, with no displays attached.
    KC
    Prehistoric Digital
