Activity › Forums › Adobe Premiere Pro › GTX 285 or Matrox RT.X2
Posted by Chin yee Lim on December 25, 2010 at 1:08 amhi, i just want to know that if i already bought GTX 285 for my PC with installed CS5. Do i still need to buy a RT.X2 card ?
Since GTX285 can perform 3 layer of realtime in CS5.
please kindly comment me.Andrew Devis replied 15 years, 8 months ago 5 Members · 15 Replies -
Todd Kopriva
December 25, 2010 at 4:23 am> Since GTX285 can perform 3 layer of realtime in CS5.
There’s no three-layer limitation if you’ve applied the updates to Premiere Pro CS5.
The most recent update is the Premiere Pro CS5 (5.0.3) update. Be sure to install that.
Technical Support for professional video software
After Effects Help & Support
Premiere Pro Help & Support
Andrew Devis
December 25, 2010 at 8:10 amFrom experience, that matrix card can be a real pain to set up. And, if you want to share your project across other machines they will need the same card … so, make sure you really need it before you buy it. The HTC should be ok for pretty much anything.
Andrew
… because it’s all about stories …
Alex Udell
December 25, 2010 at 5:00 pmI am a huge fan of Matrox.
I was also a user of RT.X2 and Axio at several facilities.However I think you’ll find that with the Mercury playback engine and Adobe shifting to that architecture that Matrox is moving on from those platforms to their external hardware.
So unless you’re getting it cheap, I’m not sure it’s a wise investment at this point. You might look at their external hardware options to be more future proof.
good luck!
Alex
Chin yee Lim
December 26, 2010 at 1:44 amHi Alex,
what is external hardware options for Matrox.
So for future enhancement better choose Matrox?
if i using RT.X2 then i need a normal GPU card is enough?
you can recommend min requirement for which GPU card that i need?Regards,
Daniel -
Chin yee Lim
December 26, 2010 at 1:52 amso if i using GTX285 + CS5, i can have multiple layer realtime ?
then what the different of GTX285 and RTX2 if both can do multiple layer realtime effect?
Chin yee Lim
December 26, 2010 at 1:55 amif another machine dont have RTX2 so the project cant be open ? or what type of error or problem i will get?
so you prefer to get GTX285 ?
Andrew Devis
December 26, 2010 at 7:14 amHi Chin
The RT2X uses hardware compression for video capture which means you must have another RT2X on any other machine that wants to work on the project. I had this problem myself and ended up having to re-capture everything so I could work on the project! I use a gtx265 with lots of RAM – 1.5G – which works very well with CS5 so a 285 will be fine, just get one Ruth as much RAM as you can.Hope this helps
Andrew… because it’s all about stories …
Andrew Devis
December 26, 2010 at 7:17 amWith not Ruth! The phone has auto correct and I keep getting it wrong sorry 🙁
Chin yee Lim
December 26, 2010 at 9:23 amHi Andrew,
Thank for your information.
So currently what type of system that you are using?
Regards,
Daniel -
Andrew Devis
December 26, 2010 at 3:05 pmRT2X hardware accelerates matrox fx and will allow you to see the capture window while you capture rather than having to use your camera monitor. You can also use an output to monitor your timeline directly. But from what you said I would say that the gtx285 is going to do all you want and that an RT2X isn’t what you really want. After all, you are still going to want a graphics card even with a matrox card.
Hope this helpsAndrew
