Activity Forums Adobe Premiere Pro GTX 260 and Premiere Pro CS4
  • GTX 260 and Premiere Pro CS4
    Posted by Sander Goorden on July 27, 2009 at 8:30 am
    Hello 🙂
    I’ve added a Nvidia GTX260 card to my system because I thought it would accelerate HD playback and rendering in Adobe Premiere Pro CS4. But still the preview is like flipping still images and rendering takes a while.
    Do I need to change settings in Premiere for it to use the GPU, or do I need some extra software from Nvidia?
    My PC has a C2D E8500 CPU with 2GB of RAM. It handles simple HD editing tasks pretty well, but it has a hard time when I get creative 😉 so that’s why I bought the Nvidia card.
    Hope anyone can help me out here, thanks!
    Sander Goorden replied 17 years, 2 months ago 2 Members · 2 Replies
  • Jon Barrie
    July 28, 2009 at 12:37 am
    Hi Sander, GPU is not used during editing or preview rendering. The accelerated export with certain Nvidia cards uses another plugin for the cards on export. It is specifically for H.264 export only.
    If you want your system to handle HD better, I’d start by upgrading your RAM from 2Gig (minimum for 1 app open) to the max you can afford and your OS can accept. 32-bit OS only can see 3Gig, 64-bit can go upto 128Gig (limited by motherboards). I’d say 8Gig is about right for HD editing. Hard Drives in a RAID 5 is going to speed read write and having that in a server takes the stress off your Editing machines CPU to run the RAID and the drives so that speeds things up again.
    HD seems like such a normal editing format these days but it’s actually stressing DV based machines to a point where the configuration needs to be so much more. My clients are still wanting to go out to DVD so I shoot in HDV and edit in DV. But those out there using Tapeless formats are just going to need a system that runs optimal for HD.
    Bottom line, it all comes down to Hard drives read write speeds, separated from the applications (actual drive not partitions), RAM, and CPU. GPU comes into After Effects, but not really Premeire Pro until you export only for H.264 using the Nvidia plugin that certain supported cards can utilize.
    1st thing you should do is upgrade your ram and even the OS to Vista 64 or wait a little and get the Win7 64 so you can throw as much ram as you can afford (motherboard can accept) in the machine.
    – JB
    Jon Barrie
    aJBprods
    http://www.jonbarrie.net
  • Sander Goorden
    July 28, 2009 at 9:03 am
    Thanks Jon,
    I will first upgrade my RAM to 8GB, get me Vista64 and a H.264 rendering plugin. After that I will read about a RAID5 server system as I’m not sure how to connect that to my workstation, but it will be fun to dive into that.
    Thanks for clearing things up so I can upgrade my video editing experience 😉
    Greets, Sander
