Activity Forums Adobe After Effects growing graphics
  • growing graphics
    Posted by Kris Tomi on October 12, 2009 at 10:14 pm
    Hi
    I have checked already the forum about making growing graphics and it helped BUT time consuming if I follow the tutorial
    https://library.creativecow.net/articles/hansen_jaysen/growing/video-tutorial.php
    I got my graphics which is black lines and curves (ornement a bit like in the tutorial) on black and white (it is a drawing = JPG document.
    If I follow the tutorial. I should draw by myself each line with his mask to make it apparears with write on effect.
    IS THERE ANOTHER WAY TO MAKE IT EASIER time saving??????
    I tried to use the auto-traced graphic which make a mask for the outLines that mean for a curve it gonna make 2 mask at least.
    is there away to SMOOTH the mask (to make it simple mask afterwards?)
    But after I am kind of stuck.
    don t know really what to do to make it appears like growing in a write on way.
    any clue?
    I did a quick test using this mask(from the auto traced with a stroke effect (animated), used as a mask to reveal the graphics. doesn t really look good.
    any idea, guys?
    THANKS FOR YOUR HELP
    i am kind of new into motion graphics and i look forward to have new ideas…
    cheers
    Micheel Leavitt replied 16 years, 10 months ago 3 Members · 2 Replies
  • Jon Geddes
    October 13, 2009 at 3:13 pm
    There is no quick and easy way to do it. Growing elements takes TIME to look good. Many hours of tweaking and tedious work for a couple seconds of animation. In fact, it took a good day or two just to animate all the growing elements from our Swan Lake DVD/Blu-ray motion menu template seen here:
    https://www.youtube.com/watch?v=-nr7ZVQ6iLI
    Jon Geddes
    http://www.precomposed.com
  • Micheel Leavitt
    October 13, 2009 at 6:11 pm
    It really depends on what you are working with. My advise (This saves myself time) is to take the full image into AE and mask the first branch, duplicate the layer, delete the mask, and draw the next branch. If it’s a “blooming” object it’s easiest to just make a whole bunch of traced leaves or other elements in AI and slap them in wherever you need them. Using Stroke is easier on the CPU from my own experiments to animate the “vines.” Yet it still takes about two-three hours from the tracing on paper to getting the masked element to masking each individual item to animation. The really great thing is if you do in the highest resolution your CPU can handle you got an amazing animated flourish that can be used again and again in any size comp. Hope this helps!
