Activity › Forums › Apple Motion › Grow Shrink behaviour problem
  • Grow Shrink behaviour problem
    Posted by Christopher Kimber on February 4, 2010 at 1:51 am
    Im shrinking an item and get the speed and size just right so end the behaviour to carry on with the rest of the animation but as soon as the behaviour is ended the item zaps back up to its original size.
    Any suggestions with this? i did see a post from 07 about this but I just couldnt understand his answer.
    Regards,
    Chris
    Stephen Smith replied 16 years, 7 months ago 3 Members · 2 Replies
  • Mark Spencer
    February 4, 2010 at 2:12 pm
    If you want the scale of an object to change and then stop, don’t use the Grow/Shrink behavior – instead, use keyframes.
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • Stephen Smith
    February 4, 2010 at 11:27 pm
    Mark is right, Keyframes work great for that. If you want to use a behavior to make an object Scale down and then come to a nice gentle halt, the one you are after is the “Move” behavior. Change it’s Z position (in 2D) and it will give the appearance of scaling up or down. When you want it to stop end the length of the behavior.
    Check out this example, this is taught in chapter 3.2 of my Moving with Motion training DVD, everything is being animated by a behavior in the video. Notice how the brown ring comes to a nice gentle stop once it scales down.
    Hope this helps and best of luck.
    Utah Video Productions
    Check out my Motion Tutorials
