Activity Forums Adobe After Effects Grow Bounds Doesn’t Work
  • Grow Bounds Doesn’t Work
    Posted by Jordan O’leary on January 18, 2008 at 7:36 pm
    Does grown bounds not work with video layers?
    I’m using shine on a Video layer that is 1080 X 1080 scaled down about half – which happens to be a texture CC Sphere. I took it and desaturated it – boosted the blacks and whites and applied a shine filter to it. Of course the rays are getting cut off but when I apply the grow bounds to the black and white layer it doesn’t work. I apply the Red Giant grow bounds – IT doesn’t work! Hmmm.
    Adam Collins replied 9 years, 10 months ago 6 Members · 17 Replies
  • 17 Replies
  • Steve Roberts
    January 18, 2008 at 7:52 pm
    I found that using Grow Bounds set to a high number, applied before Shine in the layer stack worked. Like Dave’s solution.
  • Jordan O’leary
    January 18, 2008 at 7:57 pm
    I am doing the pre-comp now – and I understand that the solves an immediate issue. But Grow Bounds is useful because you can effect the layer right there instead of opening the comp to futz. I don’t get why it’s not working.
  • Jordan O’leary
    January 18, 2008 at 7:58 pm
    I tried that with an extreme number and on the top layer. No go.
  • Steve Roberts
    January 18, 2008 at 8:04 pm
    If you look at the effects palette (the effects applied to the layer used as the texture for the sphere), here’s what I have, top-to-bottom:
    CC sphere
    Grow bounds
    Shine
    It’s one layer in one comp. AE 7.
  • Jordan O’leary
    January 18, 2008 at 8:12 pm
    I didn’t clarify. I had rendered out the CC Sphere into a vid. so now it’s just a square pixel 1080 X 1080 Animation codec vid. BUT! I also tried putting shine on a solid that was smaller than my comp and I put gow bounds on it and it STILL didn’t work.
  • Jordan O’leary
    January 18, 2008 at 8:19 pm
    Already tried. No go.
  • Steve Roberts
    Yeah. Like I said. Twice before. 😉
  • Steve Roberts
    January 18, 2008 at 8:22 pm
    Okay, Try doing what I did. One layer, one comp. Drag the footage into the comp, then apply Sphere, Grow Bounds, then Shine. If it doesn’t work, can you post a screengrab of the timeline, comp window and effects palette?
  • Jordan O’leary
    January 18, 2008 at 8:26 pm
    Standby – I’m in the middle of a render.
  • Jordan O’leary
    January 18, 2008 at 11:08 pm
    Here you Go
