Activity Forums Maxon Cinema 4D grow area affected by JOINT ?+
  • grow area affected by JOINT ?+
    Posted by Mauricio Barrientos on September 9, 2023 at 3:44 pm
    Is there a way to expand the selection of polygons reached by the JOINT?
    In other words: when we select polygons [[normally]] and we want the selection to grow reaching the closest polygons, we press [[U+Y]] right?
    I ask:
    Is there a method to do the same, but with the JOINT and to reach and grow the area affected by that JOINT?
    It is possible, is there any way?
    I always appreciate any comments, thank you!!!
    Mauricio Barrientos replied 2 years, 11 months ago 2 Members · 2 Replies
  • Kouraib Abdmalek
    September 10, 2023 at 1:18 pm
    Hi Mauricio,
    If we look how the tool works, I don’t think you can do that because you are trying to weight polygons, instead of vertices, if you increase the folding edges and manually weight corresponding vertices you’ll find out a way to fulfill your needs.
    Hope that will help you.
  • Mauricio Barrientos
    September 10, 2023 at 3:23 pm
    ok .. i understand ….
    i make manually this morning ..
    take time but work
    thanks
