Activity Forums Apple Motion Groups of animation frames to QT via Motion
  • Groups of animation frames to QT via Motion
    Posted by Godfrey Pye on March 2, 2007 at 6:49 pm
    I am editing an animated promo, getting pictures from the animation house as groups of consecutive frames.
    They are TIFF
    Godfrey Pye replied 19 years, 6 months ago 2 Members · 2 Replies
  • Arnie Schlissel
    March 5, 2007 at 12:09 am
    You can actually do this in Quicktime directly, without using Motion at all.
    In QT Pro, simply go to File>Open Image Sequence, navigate to the folder that has the image sequence in it, select the 1st frame & click the ‘Open’ button. Then you can export the image sequence directly into the same codec that your editor is using.
    Arnie
    Now in post: Peristroika, a film by Slava Tsukerman
    https://www.arniepix.com/blog
  • Godfrey Pye
    March 5, 2007 at 12:41 am
    Thank you Slave, I’ve actually done that but I thought the Motion idea was somehow ‘ cooler’ – it’s just that I am uncertain about my own ignarance when setting the parameters. Maybe I’ll go back to the way you suggest.
    Godfrey
