Activity Forums Adobe Audition group normalize problem
  • group normalize problem
    Posted by John Smith on October 7, 2006 at 10:04 pm
    I’m trying to equalize the volume of two rock music tracks and the group waveform normalize effect doesn’t seem to be helping.
    The statistics for both tracks are below.
    I used the “normalize to average level of source files” recommended for each track (ie. -5.1 dB for track one and – 9.9 dB for track two).
    I have also made sure to checkmark the “equal loudness contour” option.
    In the end both waveforms “visually” look similar but “audibly” (perceived volume) they are very different. Track one is considerably quieter than track two. It’s as if the “equal loudness contour” option
    is not working in this case.
    Any tips on what I’m doing wrong in trying to equalize the volume of these tracks is greatly appreciated.
    ……….Eq Loud | Loud | Max | Avg
    track 1: -5.1 -9.42 -4.09 -12.02
    track 2: -9.91 -10.72 -5.6 -12.06
    The clipping percentage for both tracks is 0.
    Willie Toth replied 19 years, 10 months ago 2 Members · 5 Replies
  • Willie Toth
    October 7, 2006 at 10:50 pm
    John,
    If you are working on the session or multi track side you won’t see a difference until you do a mixdown but as you said you will hear one … Why are you normalizing at such a low volume? I would suggest reading up on the hard limit function since it will fatten up the tracks and limit the peaks where the normalize only limits the peaks … Are these tracks going to be mixdown together? Explain more of what you are trying to accomplish with the project ………. WILLIE
  • John Smith
    October 8, 2006 at 10:12 pm
    The two tracks will appear next to one another on a cdr of customly arranged songs. The two songs won’t be mixed together, but because they are side by side in song order, their volume differences are noticeable as one song leds to the next in play mode.
    Really what I am doing with these two songs is that I’m putting Adobe Audition’s claim about the Group Waveform Normalize effect to the test. See their help file statement below about making “sure that all tracks on the CD have a consistent volume.”
    Normalizing groups of files
    If you’re getting ready to master an audio CD, using Group Waveform Normalize is a great way to make sure that all tracks on the CD have a consistent volume.
    I challenge this statement and I don’t think Adobe Audition can do this consistently. In addition normalizing peak values I think RMS normalization is also important for this process to work properly. Here are more help file tips:
    Use the following options in the Normalize tab to specify how you want to normalize the waveforms:
    Normalization
    Specifies whether to normalize to an average level or a specific level you enter in decibels.
    Note: The Normalization option doesn’t use percentages, unlike the Normalize effect, because it is RMS-based rather than peak-based.
    Use Equal Loudness Contour
    Applies an equal loudness contour, where the middle frequencies are most important. Because the human ear is much more sensitive to frequencies between 2 kHz and 4 kHz, two different pieces of audio with the same RMS amplitude but with different frequencies will have different apparent volumes. Select this option to ensure that audio has the same perceived loudness, regardless of what frequencies are present.
    I was hoping the Equal Loudness Contour would correct what I hear as a different “perceived loudness” between both songs. But it did not do anything with the fact that one song is clearly louder than the other one.
    As you suggested, I applied a hard limit (of 4 dB in this case) to the quieter song and this effect has helped to make both songs more equal in terms of “perceived loudness.” The hard limiting effect is a great tool and I love working with it, but if I had to do this “manual” correction to several songs in a collection of 100 mp3’s going on a cdr, for example, it would be quite a laborous task. And even with this I’m guessing at the dB value to enter; in this case, 4 dB was a good choice but that was luck.
    So I’m back to wanting Adobe Audition to do the work for me; that is, equalize the RMS perceived loudness values
    of two or more songs so that the volume levels from one song to the next will sound consistent or as close as possible.
    This sounds like it should be simple to do but my experience has shown that it can sometimes be a challenge, particularly with songs that don’t have closely matched RMS loudness values. In the end I’m trying to get Adobe Audition to do this fine tuning automatically, but I don’t think it can in all cases. My conclusion is that manual corrections “after” RMS normalization may well be necessary with one or more songs that are being prepared for burning on a cdr. And I’m not being too picky in my judgements, but if one song is considerably louder than the next in a set of songs then I feel RMS normalization has failed me.
  • Willie Toth
    October 10, 2006 at 1:18 pm
    John,
    Quality audio requires taking the time to make it right … I think the problem you are having is due to the original MP 3 file and not Audition … Unlike other file types audio isn’t a click point and shoot … Sorry you feel Audition has not lived up to it’s rep … In the 9 years I have been using Audition I have found there isn’t much that it can’t do but then I am willing to spend hours on a 5 minute clip if that is what is required … Good luck to you … WILLIE
  • John Smith
    October 10, 2006 at 10:14 pm
    I start out editing in 32 bit wave format and then finalize the recording by saving it in mp3 when required for disc space considerations. I do appreciate the time these things can take; I too spend hours on editing and I suppose the truth is there are no quick fixes.
  • Willie Toth
    October 11, 2006 at 1:45 am
    John,
    Sometimes we have to do things the hard way … Have a great evening
    WILLIE
