Activity Forums Adobe Premiere Pro Greetings everybody,I have a trimming Q
  • Greetings everybody,I have a trimming Q
    Posted by Gil Sabag on June 30, 2010 at 10:49 am
    I’v put several short clips on my timeline one after the other and I would like to trim 1 second from each clip at the start and the end of each clip, is there a tool that I can use in order for me to trim all of the clips at once? or continue what I’m doing and trim them one by one?
    I Hope there is such a tool it will save me a lllooottt of time.Thank you.Gil.
    Brenny Boy replied 16 years, 2 months ago 2 Members · 6 Replies
  • Gil Sabag
    June 30, 2010 at 12:18 pm
    I’v started to edit HD footage and I’m running cs4 on a prety strong pc, I’m editing 1440 by 1080 footage,and it has a problem playing realtime when I’m using video effects trough a 3rd party softwears,such as boris bcc and new blue,it plays very slow and even get stuck.I have a matrox rtx.2 card that I didn’t install on my pc,shall I use it? or it will be better if I’ll upgrade to cs5 and the mecury engine will work better(altough my video card is quadro fx 1800)? please help me I’v got to use effects in my line of work,any ideas what do I do?
    Thanks Gil.
  • Brenny Boy
    June 30, 2010 at 2:34 pm
    Hi Gil,
    Do you have CS4. If so you can Select all your Clips in the Bin and press a little icon (Conform to Timeline) at the base of the bin window and this will bring up a dialog box where you can choose to overlap your clips by as many frames as you choose. Just untick the
    cross dissolve option. hope this helps.
  • Brenny Boy
    June 30, 2010 at 2:55 pm
    Hi Gil,
    I would first check with matrox to see if the Boris Effects are compatible with the Rt.x2 If they are you should install the Rt.x2
    card and you should use the Matrox HD presets within Premiere.
    Hope that helps.
  • Gil Sabag
    June 30, 2010 at 5:08 pm
    If the matrox will work like he worked for on cs3 when I edit dv format, so i Don’t need any 3rd party softwears because the matrox comes with it’s own set of video effects and i know how to do with presets by heart,the question is if I can still use now that I’m working with HD? and like I said our studio’s camera shoots only 1440 by 1080i and i remember someone mentioned that thats the highest HD format matrox rtx.2 can work with,so I won’t to know if I can still ride this card untile we decide the next upgrade in our studio?
  • Gil Sabag
    June 30, 2010 at 5:15 pm
    I do work with cs4 and I didn’t see the confirm to timline icon but I do have the automate to sequence icon wich Prety much helps,thanks for remind me.
  • Brenny Boy
    July 1, 2010 at 12:09 pm
    Hi Gil,
    I use the RT.x2 in conjunction with Premiere CS4 to Edit HD. If you are installing the Matrox Card Make sure to follow Matrox instructions to the Letter. You will first need to Update Premiere CS4 to the latest Version 4.2 (Go into Premiere under Help you will see the Update Option.)
    Next you will need to Download the Latest Matrox MX Tools for the Card.
    good Luck and happy editing.
