Activity Forums Apple Final Cut Pro Legacy Greenscreen: Secondary Color Correction after using Color Key?
  • Greenscreen: Secondary Color Correction after using Color Key?
    Posted by Dustin Parsons on October 15, 2009 at 10:07 pm
    I have an actress green screened and I’m trying to get rid of the green that shows up in her hair when she does big movements. The easiest way I could think to do this is just use the 3-Way Color Corrector, isolate the green in her hair, and change that to brown.
    The problem I’m running into is that when I put the Color Corrector under the Color Key and isolate the greens everything that’s keyed turns opaque black.
    Is there a way I can add a secondary color corrector after a color key to clean up the spill?
    Mac Pro | Leopard 10.5.5
    2.66GHz Dual-Core Intel Xeon | 4GB Ram
    Final Cut Pro Studio 2 | Avid Media Composer
    Stu Siegal replied 16 years, 10 months ago 6 Members · 11 Replies
  • 11 Replies
  • John Fishback
    October 15, 2009 at 10:14 pm
    What keyer are you using? Most good ones have a spill suppression capability that should handle the green you are seeing.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Dustin Parsons
    October 15, 2009 at 10:23 pm
    I’m using the Color Key filter that comes with FCP. I have options to change the Tolerance, Edge Thin, and Edge Feather but no spill suppression.
  • Kevin Monahan
  • Tom Wolsky
    October 15, 2009 at 10:24 pm
    Apply the Spill Suppressor filter from the Key submenu.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
  • Michael Gissing
    October 15, 2009 at 10:25 pm
    Or make a Qt file of the keyed shot and then apply CC
  • Dustin Parsons
    October 15, 2009 at 10:34 pm
    Good suggestion but I need more control. The green is very subtle and the spill suppressor starts affecting other parts of the image before the green is completely gone.
  • Dustin Parsons
    October 15, 2009 at 10:37 pm
    Results are the same – the invisible keyed areas turn opaque black. Thanks for the suggestion though. Hadn’t though of trying that.
  • Dustin Parsons
    October 15, 2009 at 10:54 pm
    That would be the ideal situation. Unfortunately my work has a very quick turnaround and I’m usually making changes up until the last minute (not my choice) so round-tripping for anything gets very time consuming.
    Agreed though, Motion/After Effects is definitely the way to go.
  • Dustin Parsons
    October 15, 2009 at 11:01 pm
    Turns out I should have been using FCP’s Chroma Keyer, it has much more control than the Color Key and for my purposes it’s getting the job done.
    Thanks for the suggestions everyone.
  • Kevin Monahan
    October 15, 2009 at 11:30 pm
