Activity Forums VEGAS Pro Green video clips VP13
  • Green video clips VP13
    Posted by Sandra Marszałek on October 24, 2018 at 12:33 pm
    Hello
    I’m trying to work with those kind of clips
    Format : MPEG-4
    Format profile : Base Media / Version 2
    Codec ID : mp42
    File size : 3.33 GiB
    Duration : 4mn 40s
    Overall bit rate mode : Variable
    Overall bit rate : 102 Mbps
    Encoded date : UTC 2018-07-08 01:00:14
    Tagged date : UTC 2018-07-08 01:00:14
    PANA : ....................................................................................
    Video
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile : High 4:2:2@L4.2
    Format settings, CABAC : Yes
    Format settings, ReFrames : 3 frames
    Format settings, GOP : M=4, N=24
    Codec ID : avc1
    Codec ID/Info : Advanced Video Coding
    Duration : 4mn 40s
    Bit rate mode : Variable
    Bit rate : 99.9 Mbps
    Maximum bit rate : 125 Mbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 50.000 fps
    Standard : Component
    Color space : YUV
    Chroma subsampling : 4:2:2
    Bit depth : 10 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.963
    Stream size : 3.26 GiB (98%)
    Color range : Limited
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    But on the timeline I have just a green screen and audio.
    What can I do to work with them?
    If I need to change them on some other program – it’s more than 200 GB :/
    Ole Kristiansen replied 7 years, 10 months ago 2 Members · 2 Replies
