Activity Forums Apple Final Cut Pro Legacy Green Slug Problem – Caused By Disk Corruption
  • Green Slug Problem – Caused By Disk Corruption
    Posted by Sean Oneil on May 16, 2007 at 6:22 pm
    I just had this issue the first time. Tried everything mentioned here (trash prefs, trash Constant Frames, etc.)
    I noticed that after trashing prefs, I could make it go away if I used my internal disk as my scratch disk. But when I changed it to my array, the problem came back.
    I ended up running Disk Warrior on the array. It found filesystem corruption and corrupt files (files I actually thought I trashed).
    This fixed the problem 100%.
    So anyone with this problem, first try power cycling all your disks. And if that doesn’t work, run Disk Warrior.
    Jeremy Garchow replied 19 years, 4 months ago 2 Members · 3 Replies
  • Jeremy Garchow
    May 16, 2007 at 7:35 pm
    I thought trashing the constant frames was supposed to fix this?
    Jeremy
  • Sean Oneil
    May 16, 2007 at 9:06 pm
    I tried that and it didn’t work. In fact I trashed the Render Files folder on all my disks.
    I’ve noticed that when running Disk Warrior in the past, it often finds problems with the “Constant Frames” folder. It’s possible that the person who discovered that trick only had that folder corrupted. But it seems the green slug thing can happen to anyone who has data corruption on a scratch disk.
  • Jeremy Garchow
    May 16, 2007 at 9:51 pm
    Hmm interesting find!
