Activity Forums Adobe After Effects green screening multiple greens?
  • green screening multiple greens?
    Posted by Kevin Cease on August 20, 2014 at 6:53 pm
    Hey guys! I have an .exr sequence that has a few different types of greens. I can’t think of a time where I have had to deal with this so I’m looking for some tips on what a good procedure might be to get the scarf out of the image? Should I be rotoscoping it? Thank you for your time
    Hannes Andersson replied 12 years, 1 month ago 3 Members · 2 Replies
  • John Cuevas
    August 21, 2014 at 2:09 pm
    A method I like is to use the Selective Color effect to get a more even green to key. Check out this tutorial, it covers the technique: https://www.youtube.com/watch?v=woZflhiwJ6Y#t=49
    For your video, you’ll probably need multiple keys though.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Hannes Andersson
    August 21, 2014 at 3:04 pm
    Primatte should be able to solve all your greens for you in one key.
    If not you could duplicate the layer and key only the scarf part. then use that layer as a trackmatte for the original layer.
    Donuan
    Digital Artist / Film Maker / VJ / Animator
    https://donuan.tv
