Activity › Forums › DSLR Video › Green screen with 5D mkiii anyone?
Rick Diamond replied 13 years, 6 months ago 8 Members · 12 Replies
Tim Keeling
February 26, 2013 at 2:26 pm“Definitely use the All-I codec”
Hi Rick,
Thanks – I took your advice when recently shooting green screen with a 5d MKiii. Would you recommend transcoding to ProRes 4444/Pro Res HQ prior to keying?
cheers,
Tim
Rick Diamond
February 27, 2013 at 12:14 amI would only transcode to ProRes if your NLE requires it (FCP). Premiere will take the 5D files natively. Transcoding will not increase your ability to pull a clean key. To benefit from ProRes, the footage would have to have been recorded directly to this codec.
Ultra Key in Premiere and Keylight in After Effects will both give you great green screen results.Good luck,
Rick
