Activity Forums DSLR Video Green screen with 5D mkiii anyone?
  • Green screen with 5D mkiii anyone?
    Posted by Jay Levi on December 1, 2012 at 4:27 pm
    Has anyone tested or has footage of greenscreen with a 5d mkiii yet?
    also while its a bit off the subject does anyone have a green screen in their studio that rolls up like papar background, i was thinking of making a home studio to shoot in my living room using something that rolls with a chain.
    Rick Diamond replied 13 years, 6 months ago 8 Members · 12 Replies
  • 12 Replies
  • Noah Kadner
    December 4, 2012 at 2:07 am
    Doable but definitely get your lighting great. Paper is ok- not idea though. If you’re doing a home studio under less than great lighting I recommend this to make your life much easier in post–
    https://www.reflecmedia.com
    Noah
    Call Box Training.
    Featuring the Panasonic GH2 and Panasonic AC160/130.
  • Brent Dunn
    December 5, 2012 at 2:52 pm
    There are many inexpensive setups, stands, backgrounds to choose from. If you do this a lot, it’s nice to have a permanent solution, but if it’s only once in a while, you can buy stands and a background.
    B& H has many to choose from as well as Digital Juice.com.
    Paper usually has some reflection which can bounce the green back onto your subject. Cloth is better. But like Noah said, get the lighting right.
    Brent Dunn
    Owner / Director / Editor
    DunnRight Films
    DunnRight Video.com
    Video Marketing Toolbox.net
    Sony EX-1,
    Canon 5D Mark II
    Canon 7D
    Mac Pro
    with Final Cut Studio Adobe CS6 Production
  • Rick Diamond
    December 5, 2012 at 3:29 pm
    The 5DM3 keys very well. Definitely use the All-I codec. Ditto on good lighting.
    Rick
  • Jay Levi
    December 5, 2012 at 4:03 pm
    so far i have 2 quartz 1000 watt lights in huge soft boxes, i got them here: https://www.backdropsource.co.uk/Productinfo.asp?id=711&pname=2000-watts-quartz-softbox-kit but with 24×36 inch sized soft boxes https://www.backdropsource.co.uk/Productinfo.asp?id=1150&pname=heat-resistant-soft-box-24inch-x-36inch , very bright alone and very nice with the boxes, you think i should get another soft box, the co,pany suggested a boom stand with one more box
  • David Rehm
    December 5, 2012 at 7:43 pm
    Have you ever considered building your own lights? Jeff Foster, who is considered one of the gurus of keying, gives this instructional video on how to build great lighting for your green screen.
    check it out:
    https://www.video2brain.com/en/courses/green-screen-workshop-the-shoot
    David
  • Jay Levi
    December 5, 2012 at 8:54 pm
    i have shot with a single quartz 1000 light and a soft box before using a 5D mkii, when i went to premiere it took one click to get chroma keying perfect, now i have 2 Quartzs lights to make sure the back ground is lit,
    this was with one subject btw, i imagine a whole band would need 2 lights front, Boom stand top and back ground to be lit well with an additional 2 lights, 5 point greenscreen system
  • David Rehm
    December 5, 2012 at 9:36 pm
    I only use the lights I built (which are 2) to light the screen. I use OnLocation for monitoring and the scopes are in “the” range it needs to be for the best conditions to key.
    Whatever works best – use it.
    David
  • Nitin Kulkarni
    December 6, 2012 at 9:17 am
    hi,
    i want to shoot highly professional green screen video. i am confused between shooting on Canon 5D Mark iii and sony pmw 500 Xdcam hd 422. i want to use 5D but am not sure about its recording format. with H.264 and 4:2:0 will be able to pull of better key? or should i go with sony 500 whic records 4:2:2 for the best results?
    nitin
  • Charles Meadows
    December 6, 2012 at 8:34 pm
    For the best results you go for the highest colour space… 4:2:2 out does 4:2:0. However, you’re talking about paper green screen in your living room so I think the colour space conversation is a little “over kill”. If you want a half decent key then 90% of it is in the lighting.
    “There’s no point in filming if you don’t have fun”
    Charles Meadows
    Creative Director
    Incubate Productions South Africa
    http://www.incubatevideo.co.za
  • Jay Levi
    December 6, 2012 at 10:08 pm
    https://www.youtube.com/watch?v=kxszmgTszpQ the EX3 seems to be great for a 4:2:0 camera, yes i agree 4:2:2 is the minimum needed for clean keying as many respected professionals put it here in the CC forums, then the lights and camera also can help if the user knows what he is doing evidently the keying in the video link is very clean, 4:2:0
