Activity › Forums › Apple Final Cut Pro Legacy › Green screen to infinite white screen effect
  • Chris Adams
    July 8, 2011 at 9:49 pm
    Well I know these videos were done in the same place I am shooting at
    https://www.youtube.com/watch?v=sA_C4YatwlY
    https://www.youtube.com/watch?v=gq_AchHDEqU
  • Alan Okey
    July 9, 2011 at 1:52 am
    You can do this with Conduit, a nodal compositing plugin from DV Garage:
    https://www.dvgarage.com/conduit-2
    There’s a video tutorial specifically showing how to push a green screen to white:
    https://www.dvgarage.com/storage/conduit-samples/conduit2_push2white.mov
    If you’re looking for a simple one-button solution, you won’t find it here. However, if you’re willing to put in a little time to watch the tutorials and understand how the tools work, you can achieve some great results.
    To reiterate Dave’s point though, your results will only be as good as your production value. If your lighting sucks, even the world’s best compositor won’t be able to get good results.
  • Chris Adams
    July 9, 2011 at 5:28 am
    well I have watched many tutorials and i know how to chroma key….
    I was just wondering if i was going for a full body shot would i run into some trouble with the carpet… if so would it just have to be a waist up shot?
    also is that Conduit effect available in the free download or would i have to purchase it?
  • Alan Okey
    July 9, 2011 at 3:08 pm
    Even if you have used other chromakeying tools or plugins in the past, if you are unfamiliar with node-based compositing software (Shake, Nuke, etc.) then you will probably need to devote some time to learning how to use Conduit.
    Conduit Suite is $199.00.
    Regarding the full body shots, if you’re not using a seamless background with good lighting, it’s unlikely that you will achieve good results.
  • Chris Tompkins
    July 9, 2011 at 3:21 pm
    That first video link was shot on a cyc wall. That is your infinite white.
    You’ll never light this well with 2 lights.
    Chris Tompkins
    Video Atlanta LLC
  • Chris Adams
    July 9, 2011 at 3:37 pm
    what about the other three videos, would I just chroma key the green out and put a white/ black background this would be my set up…..
    https://www.youtube.com/watch?v=KuVwSSvbG44&feature=player_embedded
  • Chris Tompkins
    July 9, 2011 at 3:57 pm
    Tropp41 could be cyc or greenscreen.
    Inferno is green screen.
    Take heed though, good looking key’s take REAL GREAT lighting and requires experience to achieve green screen work.
    Chris Tompkins
    Video Atlanta LLC
