Activity › Forums › Apple Final Cut Pro Legacy › green screen dv pal and pro res
  • green screen dv pal and pro res
    Posted by Tas Underwood on June 15, 2011 at 4:33 pm
    Hi there,
    I have some footage that I have captured on a Z7 (M2T files). I have then encoded them to apple pro res using Mpeg Streamclip and then keying it in final cut. This seems to be a slow process and was wondering what the best process is. Can i put the prores files into After Effects and export. The final file format doesnt have to be HD.
    Anyones help on this would be massively appreciated!!!
    Tas Underwood replied 15 years, 3 months ago 2 Members · 3 Replies
  • Tas Underwood
    June 15, 2011 at 7:01 pm
    The rendering in final cut is slow and converting to pro res from mpeg streamclip. Is this the right process to follow?
  • Brendan Maghran
    June 15, 2011 at 7:44 pm
    Sounds like you’re doing fine, compositing isn’t exactly the fastest of all processes. Are you asking about keying in AE?
  • Tas Underwood
    June 15, 2011 at 7:51 pm
    Yeah was wondering whether it was better to import pro res files into ae then use keylight and export. But is animation codec only one that will work with transparency?
