Activity › Forums › Cinematography › Green Screen Camera
  • Green Screen Camera
    Posted by Bob Murray on February 5, 2008 at 11:26 pm
    I will be involved in an interior green screen shoot and need to choose between a HDX-900 and a XDCam HD camera, was told it is a 370? I will be recording to tape or disc to digitize later. The final spot will be HD and can be either 1080 or 720. Can anyone make a recommendation between these two cameras? Thanks for your expertise.
    Bj Ahlen replied 18 years, 7 months ago 3 Members · 2 Replies
  • Emre Tufekci s.o.a.
    February 6, 2008 at 2:13 am
    If you are going to do green screen, HDX-900 is the only way to go. It has a 4:2:2 colorspace at 100mbs versus 4:2:0 colorspace at 35mbs.
    Emre
    http://www.productionpit.com
    Boxx Tech PC, dual-dual AMD 2.0,4BG ram,Avidexpress HD w/Mojo,UVW-1800,DSR-25, Adobe Premium CS3.Gspeed ES.Steadicam OP/Owner.
    “Creative cow is udder madness.”
  • Bj Ahlen
    February 13, 2008 at 7:14 pm
    The HDX900 is a 2/3″ camera which can be a great help or a great hindrance, depanding on if you want a narrow or a wide DOF. It has 1280×720 CCDs, so if your deliverable isn’t 720p, you’ll be working with uprezzed footage.
    The XDCAM-HD you’re referring to is probably a CineAlta F-350, and some people have even suggested it keys better than a VariCam. I’ll stay out of that debate, because I haven’t tested them side-by-side.
    What is clear is that you cannot compare the efficiency of an intraframe codec such as DVCPROHD with a GOP codec as used in XDCAM-HD.
    In a lot of situations, footage shot with the XDCAM-HD 35 Mbps HQ codec can be considered to be less compressed than the same footage shot with 100 Mbps DVCPROHD.
    There are exceptions to this, but the math is very simple and our eyes can confirm it.
    My recommendation: rent both for a day, or worst case do a simple test at the rental company and bring some footage back to look at in your own NLE/compositor.
    Personally, I hate working with cameras I don’t know inside out. Better to use a camera you really know than some other new camera that is “10% better” but with many unknowns.
