Activity Forums Adobe After Effects Green Screen Actor in Element 3d – Matchmoving
  • Green Screen Actor in Element 3d – Matchmoving
    Posted by David Jack on March 17, 2021 at 3:45 am
    I have set a green screen with markers and everything….I want to insert the actor in a 3d scene in element 3d in after effects. How can i do the camera, the matchmoving?
    Andy Kiernan replied 5 years, 5 months ago 2 Members · 3 Replies
  • Andy Kiernan
    March 17, 2021 at 1:31 pm
    Use the 3d camera tracker in AE on the GS footage and extract the cam and a position null. Then use that for your E3D scene, you will most likely have to ‘fit’ it but that’s to be expected
  • David Jack
    March 17, 2021 at 11:07 pm
    I have done it. But idoesnt work. The 3d scene moves in a wierd way.
    SHould i link the null to the E3D solid or how should i move on?
  • Andy Kiernan
    March 18, 2021 at 2:16 pm
    I don’t have E3D on this machine, but from memory, I think you will need to copy the 3d position from the Null to the position of the E3D emitter.
