Activity › Forums › Apple Final Cut Pro Legacy › Green Screen
Green Screen
Posted by Chelsea Womack on September 23, 2009 at 3:50 pmI’m editing in Final Cut Pro 6.0 and need to key out a green screen. My problem is that the lady doing the interview is wearing a blouse with blue & green flowers. When I use the chroma keyer, I end up eventually getting holes where the green in her blouse is. Or I end up with a green halo around her when I don’t have the holes. Any help would be greatly appreciated. I tried uploading a photo, but the neither the thumbnail or the code popped up.
David Parke replied 17 years ago 7 Members · 13 Replies -
Chelsea Womack
September 23, 2009 at 4:03 pmI think I just solved my own problem. 2 layers and a garbage matte.
Kevin Monahan
September 23, 2009 at 4:07 pmNice job!
Kevin Monahan
http://www.fcpworld.com
Author – Motion Graphics and Effects in Final Cut Pro -
Alex Elkins
September 23, 2009 at 4:22 pmHi Chelsea,
The first thing to do is shout at the camera operator who didn’t see this coming…
Do you have After Effects at all? You’ll find the keying tools there much more effective. My advice for either application though, would be to use a number of duplicated layers, each masked/cropped so that you’re only targeting a specific portion of the image.
For example, Layer 1 would be the interviewer, so crop the image so you just see them, and Layer 2 would be the subject, so just crop around the subject. Then you can control the keying a bit more effectively. This is MUCH easier to do in After Effects, and you get better results.
Someone may be able to advise on a method with Motion, but I’m not familiar with it myself.All the best,
Alex -
Alex Elkins
September 23, 2009 at 4:22 pmNever mind, you solved it before I finished posting my response. Nice one.
John Ward
September 23, 2009 at 4:29 pmHello, there –
there are many more elegant ways to take care of this problem but I’m assuming you want / have to stay in Final Cut. We recently had the same problem with someone wearing a green tie to a green-screen shoot. If your subject isn’t moving too much, duplicate the clip above your current one, remove the key on the duplicate and use a garbage matte to keep the ‘interior’ of your subject in. You’ll probably want to download an 8-point matte or something more flexible than the 4-point FCP has and you’ll want to soften the edges a bunch. If your subject is moving around a lot this can be extremely time-consuming as you’ll need to continuously move the points of the matte. If you have access to AfterEffects you can use some other tools to make this go faster. Hate to say it but there’s no easy way out of this type of thing.
John Ward
Editor / Animator,
Synergetic Productionsjohn@synergeticproductions.com
https://www.synergeticproductions.com
315.437.7533 -
Chelsea Womack
September 23, 2009 at 4:45 pmThanks for the advice everyone. While the 8 point garbage matte seems to be the solution, I am getting a “shadow” effect on one of the layers. Basically where the 2 edges of the layers meet there’s a gray shadow. I’m still having issues uploading a photo. Grr.
greenscreen2.jpg [x]
Alex Elkins
September 23, 2009 at 4:47 pm[Chelsea Womack] “Basically where the 2 edges of the layers meet there’s a gray shadow.”
It sounds like one of your layers may have some of the subject keyed out, so you’re seeing FCPs black backround showing through slightly. Have you feathered the edge of one of the mattes? Try un-feathering a little and see if the problem is reduced.
All the best,
Alex Elkins -
Chelsea Womack
September 23, 2009 at 4:50 pmOk, once again nevermind. I had a garbage matte on both layers instead of just the bottom layer. Sorry for posting before thinking!
Neal Fox
September 23, 2009 at 5:11 pmOK. The seq settings was the problem. I no longer get the red bar AND the matte points go where expected.
Thanks everyone. Just one more question:
I’m on an old G5 and the hi def is taxing the computer. I really didn’t need HD but now I can’t re-shoot. So is there an easy way to make the hi def footage into SD? I can still do it in HD but it would slow the process way down.
Thanks.
