Activity › Forums › AJA Video Systems › Green Noise around graphic with alpha channel
  • Green Noise around graphic with alpha channel
    Posted by Johnnie Travis on November 2, 2005 at 5:42 pm
    I’m having a problem with a graphic that I’m trying to key over footage in FCP 5. There’s green noise surrounding the alpha channel. I created the graphic in Photoshop and the alpha channel is clean. Any ideas?
    10.4.3
    FCP 5.0.3
    AJA Io
    Alexander Serpico replied 20 years, 10 months ago 3 Members · 3 Replies
  • Joe Murray
    November 4, 2005 at 2:13 am
    I have this problem also, but I don’t think it’s related to the IO. More likely a problem with FCP itself. I pretty much avoid using Photoshop files for uncompressed graphics because of this and some other weird issues. Targa files with alpha channels are much more reliable and clean in my experience. I know, it takes longer to create them, but it just works. I’d be glad to hear from anyone who’s found a way around the green digital noise problem with psd files.
    Joe Murray
  • Johnnie Travis
    November 4, 2005 at 3:25 am
    Joe, I found that if I apply a directional blur vertically set at 1 pixel, the green artifacts don’t show up in FCP. Let me know if that works for you. Thanks for the reply.
  • Alexander Serpico
    November 9, 2005 at 9:08 pm
    check the Kona forum for another discussion of this same Final Cut Problem….
    https://forums.creativecow.net/cgi-bin/new_read_post.cgi?univpostid=856777&forumid=98&postid=856777&pview=t
