Activity Forums Apple Final Cut Pro Legacy green line on the bottom of frame
  • green line on the bottom of frame
    Posted by Chris Balogh on May 13, 2009 at 12:38 pm
    When I export videos from FCP for some reason there tends to be a green line on the very bottom of the frame, how do I get rid of it and what is causing it? Thanks in advance.
    Chris Balogh replied 17 years, 3 months ago 5 Members · 5 Replies
  • Rafael Amador
    May 13, 2009 at 1:02 pm
    Hi Chris,
    If you give some info about your system and project may be we can find something.
    I had that some time ago when using some free plugins that probably the were no debugged.
    rafael
    http://www.nagavideo.com
  • Andrew Evans
    May 13, 2009 at 3:13 pm
    i have had a similar problem. for me it happens when slow motion is being de-interlaced.
  • John Pale
    May 13, 2009 at 5:49 pm
    i have seen this too. I usually just use the crop controls in the motion tab to eliminate it.
  • Michael Gossen
    May 13, 2009 at 8:13 pm
    Try turning off ‘Frame Blending’ if you can. Sometimes it gets too choppy. If it does, you will have to scale up the clip 2-3%.
    Michael Gossen
    Helium Digital Media
  • Chris Balogh
    May 14, 2009 at 5:26 pm
    thanks to all. It was just a problem of scaling it a tiny bit higher like 2 percent or so.
