Activity Forums Apple Final Cut Pro Legacy Green line on captured footage
  • Green line on captured footage
    Posted by Brandon Carter on February 2, 2010 at 7:28 pm
    I am working in FCPS2. We shoot on XHA1’s, several in fact, and the issue persists so its not a camera issue. Capture is done through an HV30 via HDMI and Blackmagic card. Out of nowhere a green line on the top edge of the footage has appeared. It simply looks like a green outline, but its only on the top. Even when I’m just playing the footage and watching via log and capture its there. At first I figured it wouldn’t be there once I captured, but it is. I have no idea where it came from or how to “turn it off”. Anybody seen this before?? TIA!
    Michael Cheung replied 16 years, 4 months ago 3 Members · 2 Replies
  • Devin Crane
    February 3, 2010 at 6:58 pm
    I’ve never captured via HDMI but sounds like a sync problem. Do you see the same green line when playing out from the HDMI onto a monitor? Is your editor hooked up to a sync source, if not you might need to dabble with some of the sync settings on you decklink card.
  • Michael Cheung
    May 16, 2010 at 8:11 pm
    Sounds like an Interlace issue to me. I’ve had similar things before in Avid, not sure about solution but certainly look into deinterlacing the footage.
    Michael Cheung
    Editor/Assistant Editor/DIT
    http://www.filmcutter.co.uk
