Activity Forums Adobe After Effects green hair on green screen gets keyed out.
  • green hair on green screen gets keyed out.
    Posted by Gerard Kenah on February 14, 2022 at 6:03 pm
    Hi Y’all, I’m doing some light key light work but one of the talent has green streaks through his hair that are almost identical to the green screen. When I key out the screen, the streaks go as well. I’m a bit stumped, but I feel like there should be an easy fix for this.
    Graham Quince replied 4 years, 6 months ago 3 Members · 3 Replies
  • Walter Soyka
    February 14, 2022 at 9:32 pm
    There is probably not an easy fix — the keyer is driven by color. If the talent needs to feature the color green, they should be shot on a blue screen instead of a green screen.
    You’re probably going to have to rotoscope. Maybe Rotobrush will help you?
    https://helpx.adobe.com/after-effects/using/roto-brush-refine-matte.html
    Rotobrush might have trouble, too, if the boundary between green hair and green screen is indistinct. Then you’ll have to do your roto by hand.
  • Gerard Kenah
    February 15, 2022 at 8:37 pm
    I appreciate it! I’ll give it a try.
    Unfortunately the talent was wearing a clown wig that had both a blue stripe and green stripe in the hair. It is a slight issue, but one hopefully that can be resolved through Rotobrush. Thanks!
  • Graham Quince
    February 19, 2022 at 12:11 pm
    You might have to stack your chromakey effects. Use one layer to key out the hair, then garbage matte that and use a second layer to key out the clothes.
