Activity › Forums › Avid Media Composer › Green Dot Using AMA, but not with Import even though correct framerate
  • Green Dot Using AMA, but not with Import even though correct framerate
    Posted by Ben Rosenblum on June 20, 2015 at 7:04 pm
    Hi I’m relatively new to the adding media side of Avid. I’ve been trying to bring media onto my 29.98 project, first starting out using AMA linked media. My footage was shot with 23.98 footage from a Canon 5d Mk ii, yet there’s this green dot that apparently lets you know when footage is the wrong framerate. I’ve edited a bit with the green dotted footage, and I’m wondering if there’s a way for me to fix this. I recently tried IMPORTING versus going the AMA/Transcoding route, and the Importing doesn’t have the green dot. Is there a reason for this? Is there a way that I can get rid of the green dot in my already edited footage?
    I’m using MC version 8.3 and Mac OS Yosemite. I’ve heard there’s some issues with Yosemite and AVID, so not sure if that may be it.
    Thanks so much for any help you can give.
    Best,
    Michael Phillips replied 11 years, 3 months ago 2 Members · 1 Reply
  • Michael Phillips
    June 21, 2015 at 1:06 am
    Although it’s hard to tell, the green indicator can be a got or a square. So it can mean that the clips has:
    1. Different frame rate
    2. Color transform (LUT)
    3. Image transform (FrameFlex)
    In this scenario, a LUT is most likely being applied automatically. Go to source settings and check the color tab and make sure there is not a transform applied. On the color transform you can delete whatever is being applied or check the “bypass” box.
    Michael
