Activity › Forums › Avid Media Composer › Green Dot / S / FrameFlex / Aspect Ratio
  • Green Dot / S / FrameFlex / Aspect Ratio
    Posted by Ben Harris on April 24, 2018 at 1:43 pm
    Sorry if this is an amateur question but something which I’ve been trying to wrap my head around and failing.
    We’ve got a 2K DCI Full 2048 x 1080 1.90:1 project with transcoded media (mostly) at the same resolution through a Da Vinci Roundtrip (Scott Freeman etc).
    When I drop any media into the timeline it appears with an ‘S’ effect over the top and a green square. I’ve managed to figure out that these mean there is a FrameFlex effect applied to the clip and that the aspect ratio is 16:9. Should it not be 1:90.1?
    We do have some footage which was shot at 16:9 but that was also transcoded to 2048×1080 to match the settings of the project and were then just planning on resizing the image as and when.
    Ben
    Ricky Barrow replied 8 years, 5 months ago 2 Members · 1 Reply
  • Ricky Barrow
    April 25, 2018 at 1:18 pm
    1920 x 1080 is true 16×9
    Ricky
