Activity Forums Apple Final Cut Pro Green and red glitches in timeline clip
  • Green and red glitches in timeline clip
    Posted by Anna Possberg on April 7, 2013 at 2:19 pm
    Hi everybody,
    I am trying to add a twixtor effect (5.4.1) in FCPX 10.0.8 to a clip but as soon as I add it the clip has red and green pixel blocks.
    The same problem with green bars and pixels I get when I am trying to render a motion clip in Compressor or direct out of Motion. This happens randomly, not with all clips.
    My graphic card is a NVIDIA 8800 GT – may this be the cause?
    Charlie Austin replied 13 years, 4 months ago 4 Members · 14 Replies
  • 14 Replies
  • Charlie Austin
    April 7, 2013 at 4:27 pm
    Which OS version are you on?
    ~”It is a poor craftsman who blames his tools.”~
    ~”The function you just attempted is not yet implemented”~
  • Anna Possberg
    April 7, 2013 at 5:23 pm
    Hi Charlie, I have an OS 10.6.8 on a Mac Pro 3.1
  • Charlie Austin
    April 7, 2013 at 5:48 pm
    [Anna Possberg] “Hi Charlie, I have an OS 10.6.8 on a Mac Pro 3.1”
    10.6.8? oohh… my guess is that’s your problem. If you can, update to OS X 10.8.3, which is where we’re at now. That bug was introduced in FCP X 10.0.6 I think, and it took an OS update to fix it. The other “solution” would be to get a copy of FCP X older than 10.0.6, but I’m not sure how you’d do that… Update the OS. It’s fun! Just back everything up first…
  • Anna Possberg
    April 7, 2013 at 5:53 pm
    Hi thanks, I intended anyway to upgrade to Mountain Lion, I just didn’t want that lousy 10.7. Would be great if my problems would be solved that easily.
    And additionally I just ordered an ATI HD 5870 to be on the safe side. Meanwhile my screen has dancing little dots all over. Hmmmm
    Cheers,
    Anna
  • Charlie Austin
    April 7, 2013 at 5:56 pm
    [Anna Possberg] “Hi thanks, I intended anyway to upgrade to Mountain Lion, I just didn’t want that lousy 10.7. Would be great if my problems would be solved that easily.
    And additionally I just ordered an ATI HD 5870 to be on the safe side. Meanwhile my screen has dancing little dots all over. Hmmmm”
    I’ll go out on a limb and say the ML upgrade and that card (I put one in my mac pro a while ago) will fix you right up. Throw in as much RAM as you can while you’re at it…
  • Anna Possberg
    April 7, 2013 at 6:12 pm
    I hope so, right now I am backing everything up and than I’ll install OS 10.8. The card should be here on Tuesday and I already have 20 GB RAM – should be enough for a decent small 4K time lapse project.
  • Charlie Austin
    April 7, 2013 at 6:20 pm
    [Anna Possberg] “I hope so, right now I am backing everything up and than I’ll install OS 10.8. The card should be here on Tuesday and I already have 20 GB RAM – should be enough for a decent small 4K time lapse project.”
    I think it’ll be fine. Good luck!
  • Charlie Austin
    April 7, 2013 at 6:35 pm
    oh… once you’ve updated, be sure to delete all the render files from the project as the funky frames will still be contained in the old ones. Maybe the event as well just to be sure…
  • Anna Possberg
    April 7, 2013 at 6:38 pm
    Thanks, good point
  • Dave Gage
    April 7, 2013 at 6:40 pm
    [Charlie Austin] “10.6.8? oohh… my guess is that’s your problem. If you can, update to OS X 10.8.3, which is where we’re at now. That bug was introduced in FCP X 10.0.6 I think, and it took an OS update to fix it. The other “solution” would be to get a copy of FCP X older than 10.0.6, but I’m not sure how you’d do that”
    Charlie,
    I’m on 10.6.8 and FCP X 10.0.4 on an early 2011 MBP i7 with 16GB RAM and everything works fine. I have archived every version of FCP X that has come out for giggles, but the combo of my OS and version of FCP X is problem free. I have loaded OS 10.8.3 and FCP X 10.0.8 on a separate partition, but haven’t had a chance to play with it. I know for a fact that the Mountain Lion OS will “break” a lot of my older software, plus I have no time to mess with that and the slightly new OS learning curve. Someday.
    Anyway, 10.6.8 and FCP X 10.0.4 work great together.
    Dave
