Activity › Forums › Apple Final Cut Pro Legacy › Grayed out HDV Choices
  • Grayed out HDV Choices
    Posted by John Roberts on September 1, 2009 at 12:36 pm
    I just got an HD tv for external monitoring but my viewing choices are grayed out. I am hooked up to a JVC HDV 720p deck through FW then hooked to the monitor through HDMI cable.
    Will this work in this configuration or will I have to make some adjustments?
    Thanks for any help
    Bo
    Chris Borjis replied 17 years ago 2 Members · 1 Reply
  • Chris Borjis
    September 1, 2009 at 5:11 pm
    which version of fcp are you on?
    initially you could not preview HDV over firewire, but I think you
    could after 6.x
    have you tried a DV preview? that should work, but I’m not sure
    it passes through HDMI for monitoring, maybe only the component
    or composite and s-video outs.
