Activity Forums Maxon Cinema 4D Grass not going through objects (using grass kit)
  • Grass not going through objects (using grass kit)
    Posted by Thomas Hendrikson on March 2, 2016 at 12:39 pm
    Hi there,
    I am trying to create a lake with mermaids laying around the edges (green screen footage), for the base plane I’m using grass kit to create realistic looking grass but it seems to go right through the mermaids. Is there a way I can prevent it from doing that?
    I was looking into making grass with the hair function in the c4d program itself but I didn’t have great results, any tips/good tutorials?…. In case I can solve my problem with that easier.
    Thanks in advance!
    Thom
    Brian Jones replied 10 years, 6 months ago 3 Members · 6 Replies
  • Adam Trachtenberg
    March 2, 2016 at 4:15 pm
    What is the grass kit?
  • Brian Jones
    March 2, 2016 at 4:17 pm
    it’s here https://boskolazovic.blogspot.ca (I haven’t had time to test it myself)
  • Brian Jones
    March 2, 2016 at 4:46 pm
    and it appears to need VRay exclusively so I’m not seeing anything useful (not having VRay)
  • Brian Jones
    for what it’s worth with C4D hair as grass you can keep the hair from going through things with the hair collider tag
  • Thomas Hendrikson
    March 2, 2016 at 5:29 pm
    Thanks Brian. Vray is annoying me. I need to create very realistic grass on large plane. Could you give me any advice on how to make it look realistic or maybe a tutorial link or so? Ive seen many on youtube but so far not the result im looking for.
  • Brian Jones
    March 3, 2016 at 2:58 am
    there’s a lot of different grasses but this GSG tut does cover some interesting stuff using Hair (this is R13 pre-Grass object but the Grass object (tag) is more limited anyway).
    https://greyscalegorilla.com/tutorials/make-grass-in-cinema-4d-using-hair/
