Activity Forums Apple Final Cut Pro Legacy Graphics from After Effects look fuzzy when I render them In Final Cut Pro
  • Graphics from After Effects look fuzzy when I render them In Final Cut Pro
    Posted by Carmen Allison on October 11, 2011 at 4:31 pm
    Hi there folks,
    I’m having an issue with my After Effects renders in FCP.
    I’m working with a HDV1080p25 Sequence and I’m trying to put a graphic over the footage with an alpha channel (rendered out from AE as lossless with alpha, as per usual). The graphic looks totally crisp until I render the sequence. Once rendered it looks awful, almost like a really low bit rate kind of look. I’ve tried changing the alpha of the clip in FCP, again, all look crisp until I render.
    Does anyone have any solutions or have encountered this problem before?
    Regards,
    Carmen.
    Carmen Allison replied 14 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
