Activity › Forums › Adobe Premiere Pro › Graphics ‘flicker’ in Premiere. How can I fix that?
  • Graphics ‘flicker’ in Premiere. How can I fix that?
    Posted by Accountneedsrealnameupdate on August 10, 2007 at 12:50 am
    I made some video files in After Effects that were original still images from photoshop. When I add them to my Premiere timeline, burn a copy, and watch them on TV the graphic elements flicker and shake up and down. Not the problem when lines are too small and they move around, but the whole entire graphic shakes up and down. I tried the flicker removal in Premiere, but no change. How can I fix this? Is there something in AE that will do a better job?
    Why does it do it in the first place?
    Tom
    Jeff Brown replied 19 years, 1 month ago 3 Members · 2 Replies
  • Vince Becquiot
    August 10, 2007 at 2:17 am
    Have you checked your levels in the waveform monitor? Saturation ?
    I would highly recommend hooking a preview monitor to After Effects as you design to make sure everything remains NTSC friendly.
    Vince
  • Jeff Brown
    August 10, 2007 at 1:32 pm
    If, as you say, the “whole graphic” is moving up and down, then I would check for– fractional pixels sizes after import, stray keyframes, mis-matched frame rates, or other things that might induce a rounding error in the image placement. That’s what the symptoms sound descriptive of.
    -jeff
