Graphics corrupted in master movie, but not FCP
I’ll try to explain this as best I can. I have a sequence of video and still images. Some images have movement on them although very subtle. In FCP you can play out the sequence and everything looks great. However, after exporting using the Quicktime Export – current settings, the resulting master self-contained file has issues with some of the graphics, but not all.
The problem. It looks like there is a TV scan line effect applied to the images. One horizontal scan line is good, but the alternating scan line is darkened. One detail. The last frame of the “corrupted” image is fine. Again, it’s not all the images and there is no rhyme or reason to which graphics.
One solution we tried was to go to the original image files and apply the NTSC Filter to each one just in case the original file maybe had illegal colors in it. This did not correct the issue.
Any thoughts?
The images are Photo-Jpeg and vary in size like say 3000×2000 and are RGB color space.
Sequence is Apple Pro Res HDTV 1080i.
FCP 6.0.5
QT 7.6
Mac OSX 10.5.6The Visual Rabbi
TheVisualChurch.com
“Crafting Visual Messages to Engage and Persuade”
