Activity › Forums › Apple Final Cut Pro Legacy › graphics behaving strangely can’t figure it out
  • graphics behaving strangely can’t figure it out
    Posted by Roli Rivelino on March 10, 2010 at 7:21 pm
    I’ve just finished an edit and while I was checking it over I noticed something a bit strange.
    Rather than use livetype, I used text within FC, some motion and some colour from the video generator, the problem is with the colour.
    I set various key frames so that a thin band of blue is revealed at the same time as my text, rather than write in a new block of colour each time, I simply double clicked on my first colour clips and then overlaid them where I needed.
    I changed the key frame values where necessary, in a couple of instances I needed to key frame opacity, so here’s where it gets a bit weird as far as I can tell.
    When I watched it back one more time before sending to compressor, my little thin blue lines weren’t showing up, even though the opacity settings said they should, when I moved the key frame down to 0 and back up to 100, they re-appeared.
    I sent to compressor and was applying various filters via my codec and I noticed in the viewer that the blue lines had disappeared again.
    I’m waiting for it to finish compressing so that I can check, but correct me if I’m wrong, the compressor viewer shows what the final outcome is going to be right?
    Anyway I’d appreciate if anyone had an answer for me, please ask if you need me to clarify my work flow.
    Many thanks.
    aka Newbie Wan Kenewbie. “The young Newbie, is now a Padawon.”
    System
    Mac Pro 2.8Gb quad core
    8Gb RAM
    1x 320Gb 7200 hardrive
    1x 1Tb 7200 hardrive
    Nvidia Geforce 8800 512mb Graphics card
    1x 1Tb external WD ‘My Book’ eSata
    Equipment
    Panasonic AG-HVX 200
    Firestore FS-100
    Roli Rivelino replied 16 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
