Activity › Forums › Apple Final Cut Pro Legacy › graphic line overlay
  • graphic line overlay
    Posted by George Cocker on March 8, 2010 at 7:09 pm
    Hi, I’d like a bit of advice re the best way to draw lines over video. I want to illustrate the trajectory of a golf ball so need to draw straight and curved lines over various video clips of golfers hitting their shots. Many thanks
    Mark Suszko replied 16 years, 6 months ago 3 Members · 4 Replies
  • Mark Suszko
    March 8, 2010 at 7:28 pm
    I think I would export a still into photoshop, play with the bezier drawing tools till I liked the results, export out just the drawing with an alpha channel in targa, png or psd format, done.
  • George Cocker
    March 8, 2010 at 7:31 pm
    Hi, apologies Mark, should have said I want to try and animate the line in real time albeit in slo mo to follow the golf ball track.
  • Dennis Leppell
    March 8, 2010 at 8:00 pm
    Then add a step to Mark’s solution: Mask or crop the line image that was made in PS, then animate the mask.
  • Mark Suszko
    March 8, 2010 at 9:26 pm
    I just did this for a quick animation of some bar graphs, it was as easy as stacking two versions of the chart; one with the x and y axis on it, the other of just the bars. keyframing the crop of the bars was dirt-simple and client loved the look. This will work for a curve as well, as long as the path doesn’t loop back on over itself. Unless your slice is as bad as mine, not likely to be a problem:-)
    Apple Motion also comes with pre-animated arrows in the “content” section, which you can somewhat modify. But I think the Photoshop method is just as good.
