Activity Forums Apple Final Cut Pro Legacy Graphic import crashes FCP
  • Graphic import crashes FCP
    Posted by Ron Dylewski on January 23, 2006 at 6:06 pm
    Hi –
    It happens fairly frequently that, when I got to import a graphic (usually larger than the default size I’m working in) FCP will crash. Doesn’t seem to matter what the graphic format is. Is there an upward size limit that could cause this, or something else at work…?
    Ron
    Ron Dylewski replied 20 years, 7 months ago 4 Members · 5 Replies
  • Kevin Monahan
    January 23, 2006 at 7:30 pm
    What is the size and format of your image? The larger the image is, the more problematic it usually is.
    Kevin Monahan
    Take My FCP Master’s Seminar!
    fcpworld.com
  • Ron Dylewski
    January 23, 2006 at 8:38 pm
    Hi –
    It was about 800px high by 600 wide. I did size it down and that solved the problem. It just seems like FCP should have a way of sensing an image that’s too big and alerting you…other than crashing! Maybe there is a SOP on this and I’ve just missed it – that’s very possible.
    Ron
  • David Bogie
    January 23, 2006 at 9:13 pm
    CMYK images can cause havoc, too.
    bogiesan
  • Steve Eisen
    January 24, 2006 at 2:10 am
    in other words, make sure it is RGB.
    Steve Eisen
    Eisen Video Productions
    Director-At-Large
    Chicago Final Cut Pro Users Group
  • Ron Dylewski
    January 25, 2006 at 9:50 pm
    Steve –
    Thanks for the tip. I’ll check to make sure someone didn’t mistakenly sve it that way. So often you just drag this stuff in assuming it’s correct!
    Ron
