Activity Forums Apple Final Cut Pro Legacy Graphic has artifacts
  • Graphic has artifacts
    Posted by Michael Prescott on November 10, 2010 at 5:30 pm
    I prepared a title card in Photoshop at 1024 x 576, text on transparent background. When it’s composited in FC (on V2 above V1), white artifacts are appearing around the edge of the letters. When I re-sized the same graphic for the NTSC version (720 x 480), there are no artifacts. Any idea what might be causing the problem?
    PAL version:
    NTSC version:
    Michael Prescott replied 15 years, 10 months ago 3 Members · 4 Replies
  • Terry Ballard
    November 10, 2010 at 5:43 pm
    Michael,
    I’ve had better success using .tiff files. Try that…
    Terry B
    MacPro two 2.26 Ghz Xeon
    MacPro RAID card
    AJA Kona3 video capture interface
    AJA K3 breakout box
    FCP & CS4
  • Michael Prescott
    November 10, 2010 at 6:33 pm
    Terry: the above pictures were JPEG’s only for posting here; its not what was used in the project. But I just discovered something interesting: the NTSC graphic was indeed saved as a TIFF, but the PAL was saved as a PNG. I had always thought the consensus in this Forum was to use PNG but I’ll redo it as a TIFF to see if its better.
    Dave: the graphic was created with a text only on a transparent background so, in Photoshop, nothing was erased. In fact, I used the exact same file for each version, only resizing for the proper aspect ratio.
  • Michael Gissing
    November 10, 2010 at 10:34 pm
    What codec were the timelines? DV will make a mess of your graphics. Also PAL is 720 x 576 so you would be better making the correct aspect and not relying on FCP to do the anamorphic distort.
  • Michael Prescott
    November 12, 2010 at 3:08 am
    The timeline codec was 8-bit uncompressed 4:2:2. I thought this would actually help the graphic look better. Also, the Sequence frame size was 720×576 even though the original graphic was created at 1024×576.
