Activity › Forums › Adobe After Effects Expressions › graph style color change and position change
  • graph style color change and position change
    Posted by Andy Engelkemier on June 20, 2011 at 6:25 pm
    I’ve got 9 bars where I want a few lines to travel up and down and change to red at the top and green at the bottom.
    I created a null object [index 1] for all of my controls.
    each indicator bar has a ColorBalance HLS, so I could script on the Hue section. It ended up being simple calculations, so I got lucky there.
    I create these expressions, but was hoping there might be a better way, like being able to do it by making the slider name equal to the layer name or something so I could just duplicate the layer?
    For now I have to rename each expression.
    Notice in the example, “height 9” is the slider which goes from 0-100
    Is there a way to do this so I don’t have to go through and change the expression on each layer manually?
    Note: I’m asking this for Learning purposes only. I’m just trying to learn new things so in the future I can create things in more efficient ways, and maybe help a few other people with similar issues. I know this might be dumb for only 9 layers, so give me a break just this once forum troll.
    example for height bar #9 of 9
    ________________________________
    Expression: Hue
    control = thisComp.layer("controls").effect("height 9")("Slider");
    -1 * control;
    Expression: Position
    X = transform.position[0];
    timesMe = 2.9 ;
    Y = transform.position[1] + 1*-( control *timesMe );
    [X,Y];
    Andy Engelkemier replied 15 years, 3 months ago 2 Members · 2 Replies
  • Dan Ebberts
    June 20, 2011 at 7:40 pm
    If you make the bar layer names the same as the control names, you should be able to just do this:
    control = thisComp.layer(“controls”).effect(name)(“Slider”);
    Dan
  • Andy Engelkemier
    June 20, 2011 at 7:50 pm
    Thanks Dan.
    I knew it was something simple like that which I just didn’t know.
    That would have saved me some time had I known that sooner.
    I’m going to go back and edit that portion tomorrow just to ensure it sinks in for next time.
