Activity Forums Adobe After Effects Graph Editor – Value of position keyframes
  • Graph Editor – Value of position keyframes
    Posted by Albert Kowalski on March 11, 2015 at 4:55 pm
    Hi! I’m trying to manipulate my position keyframes but not their speed, only their values. Here you can see how the keyframes are represented in graph editor:
    What I want to do is make the values smaller relative to each other so the curve would be less… curvy 🙂 Thanks to that all the movement of the TRACKER clip will be the same but less dynamic. For example the “highest” keyframe would be 1650px and the “lowest” would be 1450px (now they are 1889px and 1312px). I don’t want to change the speed of the movement! What I noticed is that only in the Position keyframes there is no handle to do it easily with one move. Here you can see the graph for Scale:
    As you can see on the there is a handle (in the red circle) where I can drag the keyframes and make their values lower relative to each other… how can I do this for Position? 🙁
    Michael Szalapski replied 11 years, 6 months ago 2 Members · 5 Replies
  • Michael Szalapski
    March 11, 2015 at 5:32 pm
    Try separating dimensions of the position.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Albert Kowalski
    March 11, 2015 at 5:33 pm
    Ok but how?
  • Michael Szalapski
    March 11, 2015 at 5:38 pm
    Read this [link]. It should help.
    – The Great Szalam
  • Albert Kowalski
    March 11, 2015 at 6:42 pm
    That was easy! Thanks 🙂
  • Michael Szalapski
    March 11, 2015 at 7:18 pm
    Glad it worked for you!
    – The Great Szalam
