Activity Forums Adobe After Effects Graduated Background terrible on broadcast monitor….
  • Graduated Background terrible on broadcast monitor….
    Posted by Dom111 on December 13, 2006 at 1:12 pm
    Hi All,
    In an animation I used a background of a point light illuminating a dark green solid to get a radial gradient style effect. The project is 16 bits and I’m using a 10 bit codec to render to a QT.
    The graduated background looks very stepped when playing it in Final Cut. (looking at it on an HD broadcast monitor).
    Are there any work arounds / codecs to avoid the ‘stepped’ background or is this just a victim of too low sample rates?
    Dom
    Marc replied 19 years, 9 months ago 3 Members · 2 Replies
  • Steve Roberts
    December 13, 2006 at 2:12 pm
    Hm. Going 16- and 10-bpc should help, but some situations (especially monochromatic gradients) just call for a little noise. I think adding some HLS noise, maybe 5%, should do.
  • Marc
    December 13, 2006 at 2:30 pm
    I’ve found that using Tinderbox’s de-band filter helps with this issue. It combines noise as well as blur.
    HTH
    M
