Activity › Forums › Adobe Audition › Gradually increase the speed of an audio clip?
Posted by Dustin Bowser on July 27, 2011 at 6:44 pmHow would I go about gradually increasing the speed of an audio clip over time in Audition?
Rousselos Aravantinos replied 15 years ago 3 Members · 5 Replies -
July 28, 2011 at 1:49 amThats what everyone is looking for.
a twixtor plugin for audio. but i think there is nothing out there yet.
There is a tool in Magix Sequoia which is called elastic audio, but as far as i remember it alternates the tonality under time curves but not the length of the clip.
Anyone knows more would be nice to tell us more. -
Jesse Ruggles
October 3, 2011 at 2:20 pmWhat version of Audition are you using? Audition 3 has a “Gliding Stretch” option within the “Stretch” effect (Effects -> Time and Pitch -> Stretch).
October 3, 2011 at 2:47 pmhey,
your response got me on fire to check for this option….
I had no idea.. so i checked for this option.
I can’t find any “Gliding Stretch”
Our app version at work is A*4.i assume adobe made some changes, or i’m blind ( quite possible )!
ty
Jesse Ruggles
October 3, 2011 at 3:22 pmIt looks like it’s still there in 4/CS5.5.
I downloaded the trial to check it out. If you switch the algorithm to Audition instead of iZotope Radius there’s a “Final Stretch” setting under “Stretch and Pitch” and that is apparently where you apply the gliding stretch options. I also checked the manual to see what it had to say and here’s what I found:
“Final Stretch or Pitch Shift (Audition algorithm)
Changes the initial Stretch or Pitch Shift setting over time, reaching the final setting at the last selected audio sample.” -
October 3, 2011 at 3:38 pmoh wow oh!!!
well i have no much experience with audition..novice almost i’d say.
i tried to google for it b4 but i guess i did it the wrong way.
Yes u r right ..
our audio guy has set this to Izotope..so it was one click away to reveal!
Thank you.
