Activity › Forums › Boris FX › Gradually change the opacity of an image from one side of the screen to the other
Posted by Michael Leibson on July 16, 2019 at 10:59 pmIs there any way of doing this?
Thanks for any tips you can share!
Peter Mcauley replied 7 years, 1 month ago 2 Members · 2 Replies -
Michael Leibson
July 19, 2019 at 5:02 pm(Many days later) I found that one solution is to create and animate a negative mask over that image, that begins by totally obscuring the image and ends — at the other side of the image — with complete visibility. Applying maximum feathering (both inside and out) contributes to a smooth-looking effect.
Peter Mcauley
August 1, 2019 at 6:35 pmHi there!
Glad to see that you figured that out! You can use either a mask or a matte to generate the result that you need, which is adding alpha channel transparency to the source shot. I would recommend trying the BCC PixelChooser to help with that process – essentially, you apply the BCC PixelChooser to the source shot, and in the filters Mask group you can generate animated geometric mask shapes with a soft feathered edge, or you can use some of the built-in animatable vignette tools in the Matte section.
You can find more info on that here :
https://borisfx.com/videos/?tags=feature:PixelChooser,product:Continuum&search=pixelchooser
Cheers,
Peter.
