Activity › Forums › Adobe Premiere Pro › Gradually change a music video clip tempo (BPM) while at the same time maintaining the pitch (Song key)
Posted by Thano Karras on December 1, 2018 at 7:14 pmHi to all,
I am doing a mashup with music video clips in Premiere Pro. I need at times to gradually change the tempo of the music video (BPM) while at the same time maintaining the pitch (Song key). So for example a song starts at 120bpm and after 60 seconds I want it to drop at 115bpm gradually in order to mix it with the next song at 115bpm. All that while maintaining the pitch constant. How I can achieve that?
Many thanx 🙂
Todd Perchert replied 7 years, 9 months ago 4 Members · 7 Replies -
Ann Bens
December 1, 2018 at 11:11 pmMIght want to look at Audition.
Adobe Certified Expert Premiere Pro CS2/CS6/CC
Adobe Community Professional -
Thano Karras
December 2, 2018 at 9:39 amHi Dave,
Thanks for the reply. I am an audio engineer, a DJ, videographer and video editor. I never done this before, that is compining all the above skills in one project. I can gradually change the speed of the music video clip with time remapping->Speed. However, the pitch changes as well. I could use the pitch shifter effect for the audio track, but that is laborious, since I have to rely on my hearing every time I need to achieve that speed ramping (The mashup has 100+ songs).
So to rephrase and be even more specific, is there a way to maintain the pitch automatically, while the speed of the clip gradually changes with speed remapping?
Thano Karras
December 2, 2018 at 9:41 amHi Ann,
Thanks for the reply. Audition will not do, it adds unnecessary steps, all I need is an automatic pitch shifter to follow the speed remapping
Thano Karras
December 2, 2018 at 4:01 pmHey Dave, I was hopping on a more automated solution. It will take more time but can be done as I described!!!
Jon Doughtie
December 3, 2018 at 4:51 pmChanging music audio speed (BPM) while maintaining pitch will require Audition. Premiere Pro on the timeline won’t get you there.
An ongoing, continued increase in speed while maintaining pitch will involve cutting up the music into discreet pieces, and gradually increasing the speed on each piece. The more small pieces, the more gradual the ramp-up in speed will appear to be. Fewer pieces, and each change will become more obvious.
There’s no means I am aware of that would give you an “adjustment wheel”, so to speak, allowing you to very gradually ramp up speed while maintaining pitch. Something may exist, but is likely specialized.
If you are unaccustomed to using Audition for managing speed, the basic techniques are demonstrated in this video.
System:
Dell Precision T7600 (x2)
Win 7 64-bit
32GB RAM
Adobe CC 2017.1 (as of 8/2017)
256GB SSD system drive
4 internal media drives RAID 5
Typically cutting short form from UHD MP4, HD MP4, and HD P2 MXF.Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Thano Karras
December 4, 2018 at 11:30 amThanks Jon for the reply, I appreciate it. Still researching, I will come back soon when I have more concrete methodology for others to know as well
Todd Perchert
December 5, 2018 at 2:46 pmI think you’d need to look into DJ software. Sounds like something that a DJ might be interested in doing. Since you are a DJ, you should have resources there. I’ve never heard anything like that in any video editing application.
TC
