Activity › Forums › Avid Media Composer › Gradual Pan Adjustments in Avid Xpress 4.6?
  • Gradual Pan Adjustments in Avid Xpress 4.6?
    Posted by Phillr on February 27, 2006 at 11:38 pm
    I’m wondering if I’m able to do a gradual pan adjustment on my audio tracks. Example: I’d like the audio to all be on the left channel, and then gradually shift towards the right channel.
    I’ve tried using key frames, but keyframes only affect gain.
    I’ve tried splitting my audio master into two clips, making the first clip 100% left, the second clip 100% right, and then adding a transition between the two clips. This didn’t work either, it would stay 100% left until the cut point, and then ‘immediately’ switch to 100% right.
    Phillr replied 20 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
